Introduction
Short battery life? Replace it to restore your playtime!
Note: This guide requires delicate soldering on small wires.
Heat the left earpiece for three minutes on high with a hair dryer to soften the adhesive holding the cover. An iOpener or a heat gun on low heat can also be used.
Insert a flat blade screwdriver between the hinge and the cover.
Use the hinge as a fulcrum to lever up the cover.
The battery is lightly adhered to the earpiece with double sided tape on the end next to the hinge. Pry it up with an opening pick.
Turn the battery over and fold it out of the way.
Grasp the blue wire with tweezers then remove it with your soldering iron.
Repeat for the yellow wire.
And finally the white wire.
To reassemble your device, follow these instructions in reverse order, gluing down the cover as the last step.
