Introduction
Safety notice:
The glass container is under vacuum and can implode. Therefore, wear gloves and safety goggles when handling !
Turn the jug upside down
The black base is screwed into the housing. Unscrew to the left.
Reach into the jug while wearing a glove
Turn the jug upside down and carefully remove the glass body and place it with the opening on a soft surface. The fused nozzle used for pumping can break off easily.
The glass body is available as a spare part (part 00441154, approx. 22 EUR incl. seal)
The seal is loosely inserted in the housing. It is usually the cause for to leak out of the thermos housing.
The seal is available as a spare part (00426033, approx. 5 EUR).
For further disassembly loosen the 3 Torx T10 screws (plastic thread ca 3.2 x 15)
Press on the black plastic point and pull apart the upper and lower part
The handle is attached to the housing with a PH2 screw.
If the handle is loose, tighten carefully so that the thread in the plastic does not tear out. The handle is not available as a spare part.
Thoroughly clean or replace the gasket before reassembly.
Use a piece of foam between the base and the glass container to apply a little more pressure to the seal, without damaging the glass container
Follow these steps in revere order to reassemble your device
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
