Boot Zipper Replacement
  1. Boot Zipper Replacement, Zipper: step 1, image 1 of 2 Boot Zipper Replacement, Zipper: step 1, image 2 of 2
    • Using a seam ripper, carefully remove the stitching at the top of the boot on either side of the zipper.
    • Only remove enough to free the zipper, about ¾ of an inch.
  2. Boot Zipper Replacement: step 2, image 1 of 3 Boot Zipper Replacement: step 2, image 2 of 3 Boot Zipper Replacement: step 2, image 3 of 3
    • Remove the stitching on the heel side of the zipper.
    • The stitches on the heel side connect four layers of material: the lining, the zipper underlay, the zipper, and the outer leather.
    • Work between the leather and the zipper by pulling apart the leather and zipper and inserting the seam ripper into the gap.
  3. Boot Zipper Replacement: step 3, image 1 of 2 Boot Zipper Replacement: step 3, image 2 of 2
    • Remove the stitching on the toe side of the zipper.
    • The stitches on the toe side connect three layers of material: the lining, the zipper, and the outer leather.
    • Set aside the original zipper.
  4. Boot Zipper Replacement: step 4, image 1 of 1
    • Remove any leftover thread.
  5. Boot Zipper Replacement: step 5, image 1 of 2 Boot Zipper Replacement: step 5, image 2 of 2
    • Measure your zipper against the boot.
    • Use a pin to mark how long it should be.
  6. Boot Zipper Replacement: step 6, image 1 of 1
    • If your zipper is too long, trim it about an inch below your pin.
  7. Boot Zipper Replacement: step 7, image 1 of 2 Boot Zipper Replacement: step 7, image 2 of 2
    • Fold down the excess fabric at the top of the zipper twice to create a right angle.
  8. Boot Zipper Replacement: step 8, image 1 of 3 Boot Zipper Replacement: step 8, image 2 of 3 Boot Zipper Replacement: step 8, image 3 of 3
    • Stitch in place.
    • Use pliers if the fabric is too thick to push the needle through easily.
  9. Boot Zipper Replacement: step 9, image 1 of 2 Boot Zipper Replacement: step 9, image 2 of 2
    • Pin your new zipper to the outer leather on the heel side.
    • Be careful to put your pins through the existing holes in the leather to avoid damaging the leather further.
  10. Boot Zipper Replacement: step 10, image 1 of 1
    • Using a backstitch, sew the zipper to the leather along the inner row of stitching.
    • Be careful to put your needle through the existing holes in the leather to avoid damaging the leather further.
  11. Boot Zipper Replacement: step 11, image 1 of 2 Boot Zipper Replacement: step 11, image 2 of 2
    • Repeat steps 8 and 9 for the toe side of the zipper.
  12. Boot Zipper Replacement: step 12, image 1 of 2 Boot Zipper Replacement: step 12, image 2 of 2
    • Pin the lining to the zipper and leather on the toe side.
  13. Boot Zipper Replacement: step 13, image 1 of 2 Boot Zipper Replacement: step 13, image 2 of 2
    • Using a backstitch, sew the lining into place along the outer row of stitching.
  14. Boot Zipper Replacement: step 14, image 1 of 2 Boot Zipper Replacement: step 14, image 2 of 2
    • Pin the lining and zipper underlay to the zipper and outer leather on the heel side.
  15. Boot Zipper Replacement: step 15, image 1 of 1
    • Using a backstitch, sew the lining and zipper underlay into place along the outer row of stitching.
  16. Boot Zipper Replacement: step 16, image 1 of 2 Boot Zipper Replacement: step 16, image 2 of 2
    • This should be the final outcome after you repair the boot.
Finish Line
Alex
258 Reputation
1 Guide authored
UC Davis, Team 4-2, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 4-2, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G2
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 73
Past 30 Days: 186
All Time: 2,435
