Introduction
Good bearings are essential for smooth ride. This guide will help you take out and replace the pulley bearings on the rear wheels of your Boosted Board. You can choose to replace the bearings with new ones, or just clean the existing bearings.
Compress the motor mount back towards the wheel.
While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
Rotate and pull counterclockwise until the wheel comes off the axle completely.
Remove the back washer from the axle.
Place the new pulley bearing inside the gear hole and use two fingers to push down evenly until it slides into place.
