BodyCraft XPress Pro Pulley Cable Replacement
    1. BodyCraft XPress Pro Pulley Cable Replacement, BodyCraft XPress Pro Pulley Cable: step 1, image 1 of 1
      • Use the ratchet to unscrew each of the 12.7 mm hex bolts from the outer case.
      • Remove the panels surrounding the weight stack.
      Ask FixBot
    2. BodyCraft XPress Pro Pulley Cable Replacement: step 2, image 1 of 2 BodyCraft XPress Pro Pulley Cable Replacement: step 2, image 2 of 2
      • Label each pulley wheel and its corresponding location as a reference for reassembly.
      • Use tape and a marker to keep track of where each part belongs.
      Ask FixBot
    3. BodyCraft XPress Pro Pulley Cable Replacement: step 3, image 1 of 2 BodyCraft XPress Pro Pulley Cable Replacement: step 3, image 2 of 2
      • Remove the pulleys.
      • Use the wrench to hold the 44.5 mm hex bolt in place.
      • Use the ratchet to remove the nut.
      • Hold the pulley wheel in place while removing the 44.5 mm hex bolt.
      • Hold the cable in place while removing the pulley wheel.
      Ask FixBot
    4. BodyCraft XPress Pro Pulley Cable Replacement: step 4, image 1 of 3 BodyCraft XPress Pro Pulley Cable Replacement: step 4, image 2 of 3 BodyCraft XPress Pro Pulley Cable Replacement: step 4, image 3 of 3
      • Use the wrench to detach the cable from the weight stack.
      • Pull the cable through and out.
      Ask FixBot
    5. BodyCraft XPress Pro Pulley Cable Replacement: step 5, image 1 of 2 BodyCraft XPress Pro Pulley Cable Replacement: step 5, image 2 of 2
      • Thread the new cable through the pulley system.
      • Use the wrench to attach the new cable to the weight stack.
      Ask FixBot
    6. BodyCraft XPress Pro Pulley Cable Replacement: step 6, image 1 of 2 BodyCraft XPress Pro Pulley Cable Replacement: step 6, image 2 of 2
      • Reattach the pulleys.
      • Hold the cable while replacing the pulley wheel.
      • Hold the pulley wheel in place while replacing the 44.5 mm hex bolt.
      • Use the ratchet to reattach the nut.
      Ask FixBot
    7. BodyCraft XPress Pro Pulley Cable Replacement: step 7, image 1 of 1
      • Reattach the panels surrounding the weight stack.
      • Use the ratchet to screw each of the 12.7 mm hex bolts back on.
      Ask FixBot
Damian Bonds
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 96
All Time: 532
