Shop the Holiday Gift Guide
Body Cover Removal
Views: 1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
81
All Time:
1,016
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Body Cover Removal
Introduction
Go to step 1 ↓
How to remove the covers from the body of the camera.
Tools
    1. Body Cover Removal, Remove back cover: step 1, image 1 of 1
      • Push down on the screw to depress the spring loaded hinge and release the door.
      Ask FixBot
    2. Body Cover Removal, Remove bottom cover: step 2, image 1 of 1
      • Remove six 5.3 mm #00 screws.
      • Remove one 3.4 mm #00 screw.
      • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
      Ask FixBot
    3. Body Cover Removal, Remove left front cover: step 3, image 1 of 1
      • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
      • Remove one 7.3 mm #00 screw.
      • Remove the remote trigger cover.
      Ask FixBot
    4. Body Cover Removal, Remove front cover: step 4, image 1 of 2 Body Cover Removal, Remove front cover: step 4, image 2 of 2
      • Remove two 5.3 mm #00 screw.
      • Gently lift up on the flash housing to help remove the cover if necessary.
      Ask FixBot
    5. Body Cover Removal, Remove right front cover: step 5, image 1 of 1
      • Remove two 3.9 mm #00 screws.
      Ask FixBot
Author
with
Sam Gustafson
14,878 Reputation
78 Guides authored
2 Guide Comments
Do you know is the leatherette is removable?
cavjer123 - Reply Share
It should be. I haven't done it but it is a separate piece from the plastic panels. Try applying some isopropyl alcohol along an edge to soften the adhesive, then work a dull scraper underneath. It should come off without too much effort.
Sam Gustafson - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 81
All Time: 1,016
