This teardown is not a repair guide. To repair your Bluetooth earphone, use our service manual.
    1. Bluetooth earphone   Disassembly, taking off the button cover: step 1, image 1 of 3 Bluetooth earphone   Disassembly, taking off the button cover: step 1, image 2 of 3 Bluetooth earphone   Disassembly, taking off the button cover: step 1, image 3 of 3
      • with some thin pliers or a blade pry open the button case the 2 pieces should come off with easy
      Ask FixBot
    2. Bluetooth earphone   Disassembly, taking apart the earphone: step 2, image 1 of 2 Bluetooth earphone   Disassembly, taking apart the earphone: step 2, image 2 of 2
      • using some thin tool separate the earphone case
      • to expose the speaker just separate it a little wait for the next step
      Ask FixBot
    3. Bluetooth earphone   Disassembly, how to expose the speaker: step 3, image 1 of 2 Bluetooth earphone   Disassembly, how to expose the speaker: step 3, image 2 of 2
      • with the sharp pliers cut away the plastic around the speaker just half way
      • push back the black part to have more room to work
      Ask FixBot
    4. Bluetooth earphone   Disassembly, how to fully expose the speaker: step 4, image 1 of 2 Bluetooth earphone   Disassembly, how to fully expose the speaker: step 4, image 2 of 2
      • take off they cover after cutting it
      • with a blade take off the white foam
      • after this step the whole earphones should be exposed
      Ask FixBot
Jose A. Loza
349 Reputation
2 Guides authored
3 Guide Comments
Hi Jose, did you happen to see the Bluetooth chip used in this product ?
Rajesh Gunasekaran - Reply Share
Hindi me batao
Iliyas Khan - Reply Share
Air phone is in direct in wire in cut how to show drink
Ajit Aa - Reply Share
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 68
All Time: 6,155
