Shop the Holiday Gift Guide
Bluetooth Ground Wire Shell Removal
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
29
All Time:
96
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Bluetooth Ground Wire Shell Removal, Remove the left earpad: step 1, image 1 of 2 Bluetooth Ground Wire Shell Removal, Remove the left earpad: step 1, image 2 of 2
      • The earpads are secured with magnets.
      • Lift the left earpad (labeled L) straight up and remove it.
      Ask FixBot
    1. Bluetooth Ground Wire Shell Removal, Remove the left ear cup: step 2, image 1 of 3 Bluetooth Ground Wire Shell Removal, Remove the left ear cup: step 2, image 2 of 3 Bluetooth Ground Wire Shell Removal, Remove the left ear cup: step 2, image 3 of 3
      • Removing the ear cup isn’t required, but can make the repair easier. You can leave the cup attached and remove it later if needed.
      • Insert a SIM eject tool, bit, or a small, straightened paperclip into the hole on the top edge of the right ear cup (labeled L).
      • Push down with your tool and pull the headband connector straight out of its socket.
      • The headband connector should slide out easily. If you're having trouble, reposition the tool and try again—you may need to angle the bit slightly.
      Ask FixBot
    1. Bluetooth Ground Wire Shell Removal, Set the left ear cup down: step 3, image 1 of 1
      • Set the left ear cup down on a soft, clean cloth to prevent scratches and help stabilize the cup during your repair.
      Ask FixBot
    2. Bluetooth Ground Wire Shell Removal, Turn the housing screws to the open position: step 4, image 1 of 2 Bluetooth Ground Wire Shell Removal, Turn the housing screws to the open position: step 4, image 2 of 2
      • Turn these screws slowly and gently, stopping when you feel resistance—about 1/4 turn. If turned too far, the locking mechanism will break.
      • Use a P5 pentalobe screwdriver to turn (not remove) the four speaker housing screws to the unlocked position:
      • Turn the top left and bottom right screws counterclockwise.
      • Turn the top right and bottom left screws clockwise.
      Ask FixBot
    3. Bluetooth Ground Wire Shell Removal, Soften the speaker housing adhesive: step 5, image 1 of 3 Bluetooth Ground Wire Shell Removal, Soften the speaker housing adhesive: step 5, image 2 of 3 Bluetooth Ground Wire Shell Removal, Soften the speaker housing adhesive: step 5, image 3 of 3
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • The perimeter of the speaker housing is secured to the cup with adhesive. This step shows a few methods to soften the adhesive so you can pry up the housing. If one isn't working, try a different method.
      • Option 1: Apply a few drops of high-concentration isopropyl alcohol (>90%) in the gap around the perimeter of the speaker housing. Wait one minute to allow the alcohol to soften the adhesive.
      • Option 2: Heat the speaker housing with an iOpener or hair dryer. Focus the heat around the perimeter, applying small amounts for short periods of time.
      • Don't heat the center of the speaker housing, or you'll damage the fragile mesh under the speaker cutouts and possibly the speaker.
      • For a detailed look at best practices for using a hair dryer, check out this guide.
      Ask FixBot
    4. Bluetooth Ground Wire Shell Removal, Pry up the speaker housing: step 6, image 1 of 3 Bluetooth Ground Wire Shell Removal, Pry up the speaker housing: step 6, image 2 of 3 Bluetooth Ground Wire Shell Removal, Pry up the speaker housing: step 6, image 3 of 3
      iSesamo Opening Tool
      $10.99
      Buy
      • The gap between the speaker housing and ear cup is extremely small. You'll need a thin tool such as a metal opening pick, iSesamo, or iFlex to pry up the housing.
      • Don't grip the iFlex or similar metal tools by the edges—they're sharp and may cut you. Consider wearing gloves to protect yourself.
      • Insert the flat side of your opening tool into the gap between the right side of the speaker housing and the lip of the ear cup (opposite the L marking).
      • Pry up the speaker housing until you can grip it with your fingers, applying constant pressure to allow the adhesive to separate.
      • If the housing isn't coming up, repeat the previous step and try again. Don't try and force the housing out or you may damage it.
      Ask FixBot
    5. Bluetooth Ground Wire Shell Removal: step 7, image 1 of 3 Bluetooth Ground Wire Shell Removal: step 7, image 2 of 3 Bluetooth Ground Wire Shell Removal: step 7, image 3 of 3
      • Don't try to fully remove the speaker housing yet—a delicate ribbon cable still connects it to the ear cup.
      • Lift the speaker housing out of the ear cup to fully separate the remaining adhesive.
      • Flip the housing over the side of the cup and prop it up so you can access the cable.
      Ask FixBot
    6. Bluetooth Ground Wire Shell Removal, Remove the speaker housing cable cover: step 8, image 1 of 2 Bluetooth Ground Wire Shell Removal, Remove the speaker housing cable cover: step 8, image 2 of 2
      FixMat
      $36.95
      Buy
      • Don’t let any screws snap onto the speaker driver diaphragm or they'll damage it. The screws will be drawn towards the center by the speaker's magnet.
      • Remove the four screws securing the cable cover:
      • One 7.5 mm‑long Torx Plus 3IP screw
      • Three 1.7 mm‑long Torx Plus 1IP screws
      Ask FixBot
    7. Bluetooth Ground Wire Shell Removal: step 9, image 1 of 3 Bluetooth Ground Wire Shell Removal: step 9, image 2 of 3 Bluetooth Ground Wire Shell Removal: step 9, image 3 of 3
      • Use tweezers to slightly lift the cover and slide it towards the center of the ear cup to remove it.
      Ask FixBot
    8. Bluetooth Ground Wire Shell Removal, Disconnect the speaker housing: step 10, image 1 of 2 Bluetooth Ground Wire Shell Removal, Disconnect the speaker housing: step 10, image 2 of 2
      • Use a spudger to pry up and disconnect the speaker housing press connector.
      Ask FixBot
    9. Bluetooth Ground Wire Shell Removal, Remove the speaker housing: step 11, image 1 of 1
      • Remove the speaker housing.
      Ask FixBot
    1. Bluetooth Ground Wire Shell Removal, Remove the speaker driver screws: step 12, image 1 of 3 Bluetooth Ground Wire Shell Removal, Remove the speaker driver screws: step 12, image 2 of 3 Bluetooth Ground Wire Shell Removal, Remove the speaker driver screws: step 12, image 3 of 3
      • Grip the screws with tweezers while loosening and removing them. Don’t let the screws snap onto the diaphragm.
      • Use a Torx Plus 3IP screwdriver to remove three speaker driver screws:
      • Two 6.0 mm‑long screws
      • One 6.0 mm‑long screw that's slightly thicker than the other two
      • Remove the 5.1 mm‑long standoff screw using one of the two methods below:
      • Apply constant downward force to avoid damaging the screw.
      • Option 1: Stick a small flathead screwdriver into one of the four notches on top of the screw and use it to slowly turn the screw.
      • Option 2: Use a Torq-Set 6 screwdriver to remove the screw, applying constant downward force to avoid damaging the screw.
      Ask FixBot
    2. Bluetooth Ground Wire Shell Removal, Remove the speaker driver: step 13, image 1 of 3 Bluetooth Ground Wire Shell Removal, Remove the speaker driver: step 13, image 2 of 3 Bluetooth Ground Wire Shell Removal, Remove the speaker driver: step 13, image 3 of 3
      • Lift the right edge of the speaker and remove it, being careful not to touch the diaphragm.
      • Set the speaker aside in a place where it won't attract small metal objects.
      Ask FixBot
    1. Bluetooth Ground Wire Shell Removal, Remove the connector cover: step 14, image 1 of 2 Bluetooth Ground Wire Shell Removal, Remove the connector cover: step 14, image 2 of 2
      • Remove the two Bluetooth board connector cover screws:
      • One 1.7 mm‑long Torx Plus 1IP screw
      Ask FixBot
    2. Bluetooth Ground Wire Shell Removal: step 15, image 1 of 3 Bluetooth Ground Wire Shell Removal: step 15, image 2 of 3 Bluetooth Ground Wire Shell Removal: step 15, image 3 of 3
      Ask FixBot
    3. Bluetooth Ground Wire Shell Removal, Disconnect the Bluetooth board: step 16, image 1 of 2 Bluetooth Ground Wire Shell Removal, Disconnect the Bluetooth board: step 16, image 2 of 2
      • Use a spudger to pry up and disconnect the press connector from under the cover you just removed.
      Ask FixBot
    4. Bluetooth Ground Wire Shell Removal: step 17, image 1 of 2 Bluetooth Ground Wire Shell Removal: step 17, image 2 of 2
      • Use a spudger to pry up and disconnect the press connector on the other end of the board.
      Ask FixBot
    5. Bluetooth Ground Wire Shell Removal: step 18, image 1 of 2 Bluetooth Ground Wire Shell Removal: step 18, image 2 of 2
      • Slide one arm of your angled tweezers under the metal neck of the coaxial connector (next to the one from the previous step) and lift straight up to disconnect it.
      Ask FixBot
    6. Bluetooth Ground Wire Shell Removal: step 19, image 1 of 2 Bluetooth Ground Wire Shell Removal: step 19, image 2 of 2
      • Use the point of a spudger to gently pull the copper hinge cable (in plastic tubing) out of its clip.
      Ask FixBot
    7. Bluetooth Ground Wire Shell Removal, Remove the Bluetooth board screw: step 20, image 1 of 2 Bluetooth Ground Wire Shell Removal, Remove the Bluetooth board screw: step 20, image 2 of 2
      • Use a Torx Plus 1IP screwdriver to remove the 3.0 mm‑long screw securing the Bluetooth board.
      Ask FixBot
    8. Bluetooth Ground Wire Shell Removal, Reposition the Bluetooth board: step 21, image 1 of 3 Bluetooth Ground Wire Shell Removal, Reposition the Bluetooth board: step 21, image 2 of 3 Bluetooth Ground Wire Shell Removal, Reposition the Bluetooth board: step 21, image 3 of 3
      • Don't try to fully remove the board yet, as a cable still connects it.
      • Stick the point of a spudger into the baord's screw hole near the hinge and pull the board towards the center of the ear cup.
      • Use your fingers to flip the board over the side so you can access the remaining connector.
      Ask FixBot
    9. Bluetooth Ground Wire Shell Removal, Disconnect the Bluetooth board: step 22, image 1 of 3 Bluetooth Ground Wire Shell Removal, Disconnect the Bluetooth board: step 22, image 2 of 3 Bluetooth Ground Wire Shell Removal, Disconnect the Bluetooth board: step 22, image 3 of 3
      • Disconnecting the power board cable is tricky and may take a few tries. Don't try to disconnect it by pulling on the cable, or you may cause damage.
      • Use the point of a spudger to press on alternating sides of the sliding connector tabs to "walk" it out of the socket.
      Ask FixBot
    10. Bluetooth Ground Wire Shell Removal, Remove the Bluetooth board: step 23, image 1 of 1
      • Remove the Bluetooth board.
      Ask FixBot
    1. Bluetooth Ground Wire Shell Removal, Detach the microphone: step 24, image 1 of 3 Bluetooth Ground Wire Shell Removal, Detach the microphone: step 24, image 2 of 3 Bluetooth Ground Wire Shell Removal, Detach the microphone: step 24, image 3 of 3
      • Mild adhesive secures the microphone cable to the ground wire shell.
      • Use a spudger and your fingers to lift all ends of the microphone cable until it fully separates from the ground wire shell.
      Ask FixBot
    2. Bluetooth Ground Wire Shell Removal, Remove the ground wire shell screws: step 25, image 1 of 2 Bluetooth Ground Wire Shell Removal, Remove the ground wire shell screws: step 25, image 2 of 2
      • Remove the five screws securing the ground wire shell:
      • One 11.8 mm‑long Torx Plus 2IP screw
      • Two 10.6 mm‑long Torx Plus 3IP screws
      • Two 9.5 mm‑long Torx Plus 3IP screws going into the side of the ear cup
      Ask FixBot
    3. Bluetooth Ground Wire Shell Removal, Remove the ground wire shell: step 26, image 1 of 3 Bluetooth Ground Wire Shell Removal, Remove the ground wire shell: step 26, image 2 of 3 Bluetooth Ground Wire Shell Removal, Remove the ground wire shell: step 26, image 3 of 3
      • Stick the point of a spudger into one of the ground wire clips screw holes and pull the board towards the center of the ear cup.
      • Use your fingers to remove the ground wire shell.
      Ask FixBot
Finish Line
Spencer Day
210,389 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 29
All Time: 96
