Shop the Holiday Gift Guide
Bluetooth Ground Wire Shell Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
12
All Time:
78
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Parts
Tools
    1. Bluetooth Ground Wire Shell Installation, Put the ground wire shell into place: step 1, image 1 of 3 Bluetooth Ground Wire Shell Installation, Put the ground wire shell into place: step 1, image 2 of 3 Bluetooth Ground Wire Shell Installation, Put the ground wire shell into place: step 1, image 3 of 3
      • Slide the ground wire shell into its recess, making sure it goes under the microphone cables.
      Ask FixBot
    2. Bluetooth Ground Wire Shell Installation, Install the ground wire shell screws: step 2, image 1 of 2 Bluetooth Ground Wire Shell Installation, Install the ground wire shell screws: step 2, image 2 of 2
      • You may need to push the ground wire under the lip of the cup to get its screw holes to line up.
      • Install the five screws securing the ground wire shell:
      • One 11.8 mm‑long Torx Plus 2IP screw
      • Two 9.5 mm‑long Torx Plus 3IP screws
      • Two 10.6 mm‑long Torx Plus 3IP screws going into the side of the ear cup
      Ask FixBot
    3. Bluetooth Ground Wire Shell Installation, Attach the microphone: step 3, image 1 of 2 Bluetooth Ground Wire Shell Installation, Attach the microphone: step 3, image 2 of 2
      • If any parts of the cable don't stay in place during the next three steps, use thin, double-sided tape to secure the cable.
      • Push the microphone cables into place on the ground wire shell, making sure the alignment holes go over their pegs.
      Ask FixBot
    4. Bluetooth Ground Wire Shell Installation: step 4, image 1 of 2 Bluetooth Ground Wire Shell Installation: step 4, image 2 of 2
      • Use the point of a spudger to gently push the gold speaker contacts into its groove.
      Ask FixBot
    5. Bluetooth Ground Wire Shell Installation: step 5, image 1 of 2 Bluetooth Ground Wire Shell Installation: step 5, image 2 of 2
      • Use a spudger or your fingers to gently push the cable back into place on the ground wire shell.
      Ask FixBot
Finish Line
Spencer Day
210,389 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 78
