Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Spudger4.9
Insert a SIM eject tool, bit, or a small, straightened paperclip into the hole on the top edge of the right ear cup (labeled L).
Push down with your tool and pull the headband connector straight out of its socket.
Set the left ear cup down on a soft, clean cloth to prevent scratches and help stabilize the cup during your repair.
Use a P5 pentalobe screwdriver to turn (not remove) the four speaker housing screws to the unlocked position:
Turn the top left and bottom right screws counterclockwise.
Turn the top right and bottom left screws clockwise.
Tool used on this step:iOpener$14.95
Option 1: Apply a few drops of high-concentration isopropyl alcohol (>90%) in the gap around the perimeter of the speaker housing. Wait one minute to allow the alcohol to soften the adhesive.
Option 2: Heat the speaker housing with an iOpener or hair dryer. Focus the heat around the perimeter, applying small amounts for short periods of time.
Tool used on this step:iSesamo Opening Tool$10.99
Insert the flat side of your opening tool into the gap between the right side of the speaker housing and the lip of the ear cup (opposite the L marking).
Pry up the speaker housing until you can grip it with your fingers, applying constant pressure to allow the adhesive to separate.
Tool used on this step:FixMat$36.95
Remove the four screws securing the cable cover:
One 7.5 mm‑long Torx Plus 3IP screw
Three 1.7 mm‑long Torx Plus 1IP screws
Use a spudger to pry up and disconnect the speaker housing press connector.
Use a Torx Plus 3IP screwdriver to remove three speaker driver screws:
Two 6.0 mm‑long screws
One 6.0 mm‑long screw that's slightly thicker than the other two
Remove the 5.1 mm‑long standoff screw using one of the two methods below:
Option 1: Stick a small flathead screwdriver into one of the four notches on top of the screw and use it to slowly turn the screw.
Option 2: Use a Torq-Set 6 screwdriver to remove the screw, applying constant downward force to avoid damaging the screw.
Lift the right edge of the speaker and remove it, being careful not to touch the diaphragm.
Remove the two Bluetooth board connector cover screws:
One 1.7 mm‑long Torx Plus 1IP screw
Use a spudger to pry up and disconnect the press connector from under the cover you just removed.
Slide one arm of your angled tweezers under the metal neck of the coaxial connector (next to the one from the previous step) and lift straight up to disconnect it.
Use a Torx Plus 1IP screwdriver to remove the 3.0 mm‑long screw securing the Bluetooth board.
Stick the point of a spudger into the baord's screw hole near the hinge and pull the board towards the center of the ear cup.
Use your fingers to flip the board over the side so you can access the remaining connector.
Use the point of a spudger to press on alternating sides of the sliding connector tabs to "walk" it out of the socket.
