Shop the Holiday Gift Guide
Bluetooth Board Installation
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
24
All Time:
108
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Bluetooth Board Installation, Connect the Bluetooth board: step 1, image 1 of 2 Bluetooth Board Installation, Connect the Bluetooth board: step 1, image 2 of 2
      • Use the point of a spudger to push on alternating sides of the copper cable's connector until it slides fully into the socket on the underside of the power board.
      • Don't grip the cable and push it into the socket—you'll likely damage the cable.
      • The connector should slide in fairly easily when oriented correctly. If it doesn't, flip the connector over and try again.
      Ask FixBot
    2. Bluetooth Board Installation, Slide the Bluetooth board into place: step 2, image 1 of 3 Bluetooth Board Installation, Slide the Bluetooth board into place: step 2, image 2 of 3 Bluetooth Board Installation, Slide the Bluetooth board into place: step 2, image 3 of 3
      • Slide the Bluetooth board into its recess, making sure none of the cables that connect to it get trapped underneath.
      • You may need to use a spudger to hold cables out of the way while inserting the board.
      Ask FixBot
    3. Bluetooth Board Installation, Install the Bluetooth board screw: step 3, image 1 of 3 Bluetooth Board Installation, Install the Bluetooth board screw: step 3, image 2 of 3 Bluetooth Board Installation, Install the Bluetooth board screw: step 3, image 3 of 3
      • Use a Torx Plus 1IP screwdriver to install the 3.0 mm‑long screw securing the Bluetooth board.
      • Make sure you're installing the screw in the correct spot as shown in the photo.
      Ask FixBot
    4. Bluetooth Board Installation: step 4, image 1 of 2 Bluetooth Board Installation: step 4, image 2 of 2
      • Use a spudger to gently push the copper hinge cable into its clip.
      • If you're having trouble, don't force the cable into the clip. Reposition it slightly and try again.
      Ask FixBot
    5. Bluetooth Board Installation, Reconnect the Bluetooth board: step 5, image 1 of 1
      • Use your finger to press down and connect the press connector on the board (nearest the hinge).
      Ask FixBot
    6. Bluetooth Board Installation: step 6, image 1 of 1
      • Use tweezers to hold the coaxial connector in place over its socket and gently press down with a spudger—the connector should "snap" into place.
      • Make sure the cable routes through the inside edge of the screw post.
      • If you're having trouble, reposition the connector and try again. Don't try to force the connector into place or you may permanently damage it.
      Ask FixBot
    7. Bluetooth Board Installation: step 7, image 1 of 1
      • Use a spudger or your finger to press down and reconnect the press connector next to the one you just connected.
      Ask FixBot
    8. Bluetooth Board Installation: step 8, image 1 of 3 Bluetooth Board Installation: step 8, image 2 of 3 Bluetooth Board Installation: step 8, image 3 of 3
      • Slide the tab on the connector cover into its slot and lay the cover down.
      Ask FixBot
    9. Bluetooth Board Installation: step 9, image 1 of 2 Bluetooth Board Installation: step 9, image 2 of 2
      • Install the two Bluetooth board connector cover screws:
      • One 7.5 mm‑long Torx Plus 3IP screw
      • One 1.7 mm‑long Torx Plus 1IP screw
      Ask FixBot
Finish Line
Spencer Day
210,389 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 24
All Time: 108
