Blu Studio HD 6.0 Battery Replacement
  1. Blu Studio HD 6.0 Battery Replacement, Rear Case: step 1, image 1 of 1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Battery Replacement, Back Panel.: step 2, image 1 of 2 Blu Studio HD 6.0 Battery Replacement, Back Panel.: step 2, image 2 of 2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Battery Replacement: step 3, image 1 of 2 Blu Studio HD 6.0 Battery Replacement: step 3, image 2 of 2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 Battery Replacement, Midframe: step 4, image 1 of 2 Blu Studio HD 6.0 Battery Replacement, Midframe: step 4, image 2 of 2
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
  5. Blu Studio HD 6.0 Battery Replacement: step 5, image 1 of 1
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
  6. Blu Studio HD 6.0 Battery Replacement: step 6, image 1 of 1
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
  7. Blu Studio HD 6.0 Battery Replacement: step 7, image 1 of 1
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
  8. Blu Studio HD 6.0 Battery Replacement, Battery: step 8, image 1 of 1
    • With your back panel and battery housing removed you can proceed to replacing your battery.
    • Locate the white indicator and wired connections.
  9. Blu Studio HD 6.0 Battery Replacement, Water Damage.: step 9, image 1 of 1
    • One way to tell if your battery needs to be replaced is water damage.
    • If you believe your phone has water damage an indicator on your battery will tell you if water has been in contact with your battery by turning pink or red.
  10. Blu Studio HD 6.0 Battery Replacement, Lifting.: step 10, image 1 of 1
    • Begin by lifting the battery from the phone frame. This can be done with plastic prying tools or tweezers.
    • The battery is held in place with thermal glue so it will offer some resistance.
  11. Blu Studio HD 6.0 Battery Replacement, Soldering.: step 11, image 1 of 1
    • This next step will involve your soldering workstation.
    • Begin by desoldering the wires.
    • At this point the battery can be removed and your replacement inserted in its place. (remember to properly dispose of your old battery).
    • Re-solder the wires back onto the new battery's connector board.(Depending on the battery replacement purchased, it may come with its own wires which will have to be desoldered as well)
  12. Blu Studio HD 6.0 Battery Replacement, Finished.: step 12, image 1 of 1
    • Your new battery should be ready to go with an ample charging.
Erik reinbolt
1,572 Reputation
3 Guides authored
USF Tampa, Team 9-1, Blackwell Fall 2014 Member of USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 Members
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 34
All Time: 46,061
