Blu Studio 5.5 S Midframe Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Blu Studio 5.5 S Midframe Replacement, Back Casing: step 1, image 1 of 1
      • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
      Ask FixBot
    2. Blu Studio 5.5 S Midframe Replacement, Applying Pressure: step 2, image 1 of 3 Blu Studio 5.5 S Midframe Replacement, Applying Pressure: step 2, image 2 of 3 Blu Studio 5.5 S Midframe Replacement, Applying Pressure: step 2, image 3 of 3
      • Place your finger in the small notch on the left side of the charging port (facing from the back).
      • Once your finger is in the notch, pull the back case towards yourself to remove it.
      Ask FixBot
    1. Blu Studio 5.5 S Midframe Replacement, Battery: step 3, image 1 of 3 Blu Studio 5.5 S Midframe Replacement, Battery: step 3, image 2 of 3 Blu Studio 5.5 S Midframe Replacement, Battery: step 3, image 3 of 3
      • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
      • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
      Ask FixBot
    1. Blu Studio 5.5 S Midframe Replacement, Midframe: step 4, image 1 of 3 Blu Studio 5.5 S Midframe Replacement, Midframe: step 4, image 2 of 3 Blu Studio 5.5 S Midframe Replacement, Midframe: step 4, image 3 of 3
      • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
      • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
      Ask FixBot
    2. Blu Studio 5.5 S Midframe Replacement, Aesthetic Bottom Case: step 5, image 1 of 1
      • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
      Ask FixBot
    3. Blu Studio 5.5 S Midframe Replacement: step 6, image 1 of 3 Blu Studio 5.5 S Midframe Replacement: step 6, image 2 of 3 Blu Studio 5.5 S Midframe Replacement: step 6, image 3 of 3
      • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
      • Pick up the inner back case and flip it over.
      Ask FixBot
Cody Dyl
804 Reputation
5 Guides authored
UMass Dartmouth, Team 4-8, Miles Fall 2014 Member of UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 228
