Introduction
Battery removal is useful because it allows you to either replace the battery or reset the phone.
In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
Place your finger in the small notch on the left side of the charging port (facing from the back).
Once your finger is in the notch, pull the back case towards yourself to remove it.
the phone i purchased does not have a notch that you described and the camera lens is in the middle and the flash is beneath
it is impossible to open without damaging case (which I already did) . why don't these idiots provide a usable manual with their product? we aren't all mind readers
Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
i try to take it out to reset the phone now it is not coming back on help please
Where can i buy a new battery for this model? I’m from Philippines. Kindly reply, thank you.
7 other people completed this guide.
