In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Community-Contributed Guide
Introduction
Go to step 1 ↓Are you unable to play Rock Band again because of the busted drum pedal? Replace the spring and re-unite the band with this easy-to-follow guide!
Turn the drum pedal on it's back and locate the two 3 mm Phillips screws near the center of the device.
Tool used on this step:Phillips #1 Screwdriver$5.49
Using a Phillips #1 Screwdriver:
Remove the two 3 mm Phillips screws.
Grab your 1/2 in. L x 1/4 in. D Compression Spring and insert it into the circular base on the base of the pedal.
Screw both 3 mm Phillips screws back into place.
Connect the Hit Kit to the drum set and boot up your console. Test the pedal at each of the three adjustable heights and jam on!
That’s it! You’ve repaired your own Hit Kit pedal and are ready for stardom!
