Blink Video Doorbell Lens Replacement
  1. Blink Video Doorbell Lens Replacement, Battery: step 1, image 1 of 3 Blink Video Doorbell Lens Replacement, Battery: step 1, image 2 of 3 Blink Video Doorbell Lens Replacement, Battery: step 1, image 3 of 3
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell Lens Replacement: step 2, image 1 of 3 Blink Video Doorbell Lens Replacement: step 2, image 2 of 3 Blink Video Doorbell Lens Replacement: step 2, image 3 of 3
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell Lens Replacement: step 3, image 1 of 3 Blink Video Doorbell Lens Replacement: step 3, image 2 of 3 Blink Video Doorbell Lens Replacement: step 3, image 3 of 3
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell Lens Replacement, Back Panel: step 4, image 1 of 3 Blink Video Doorbell Lens Replacement, Back Panel: step 4, image 2 of 3 Blink Video Doorbell Lens Replacement, Back Panel: step 4, image 3 of 3
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
  5. Blink Video Doorbell Lens Replacement, Lens: step 5, image 1 of 3 Blink Video Doorbell Lens Replacement, Lens: step 5, image 2 of 3 Blink Video Doorbell Lens Replacement, Lens: step 5, image 3 of 3
    • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
    • Use an opening tool to release the motherboard from the device.
  6. Blink Video Doorbell Lens Replacement: step 6, image 1 of 2 Blink Video Doorbell Lens Replacement: step 6, image 2 of 2
    • Carefully lift up the small daughterboard which contains the camera.
    • Remove two 5 mm screws from the back of the camera using a Phillips #0 screwdriver.
  7. Blink Video Doorbell Lens Replacement: step 7, image 1 of 2 Blink Video Doorbell Lens Replacement: step 7, image 2 of 2
    • Use tweezers to detach the white connector from the adapter on the motherboard.
    • Remove the lens.
Kayla Crai
510 Reputation
4 Guides authored
UMass Dartmouth, Team 1-1, Konn Fall 2024 Member of UMass Dartmouth, Team 1-1, Konn Fall 2024
UMASSD-KONN-F24S1G1
4 Members
5 Guides authored
5 Guide Comments
Is it available to purchase the lens
William - Reply
Where can the replacement module/adapter be purchased?
William Meade - Reply
Where can we get the right replacement?
Very helpful article otherwise!
Jesse Jewell - Reply
Where can I get a replacement lens.\nPlease
colin burton - Reply
This would be useful if we could get spare lens, I've got 3 now that have all fogged up and while baking them in the oven improves them they are never as good as when they were new. I've searched high and low and cannot believe Blink are using a bespoke lense, There must be ones out there ??
ChrisB - Reply
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 206
All Time: 1,586
