Introduction
Use this guide to replace the daughterboard in your Blink Video Doorbell.
Push the opening key into the small opening with the two gray buttons on the bottom of the device.
Push the device up from the mount and slide it off.
Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
Use an opening tool to release the motherboard from the device.
