Dell XPS 15 9500 SSD Replacement
  1. Dell XPS 15 9500 SSD Replacement, Base Panel: step 1, image 1 of 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 SSD Replacement: step 2, image 1 of 2 Dell XPS 15 9500 SSD Replacement: step 2, image 2 of 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 SSD Replacement, SSD: step 3, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the single 3.0 mm screw on the right side of the SSD.
  4. Dell XPS 15 9500 SSD Replacement: step 4, image 1 of 1
    • Lift the card a few millimeters, then pull it directly out of its slot.
  5. Dell XPS 15 9500 SSD Replacement: step 5, image 1 of 2 Dell XPS 15 9500 SSD Replacement: step 5, image 2 of 2
    • If you wish to install a second SSD, there is an empty slot for an additional SSD underneath the copper cover. If you're just replacing the existing SSD, stop here.
    • Use a Phillips #000 screwdriver to remove the one 3.0 mm screw on the left side of the SSD slot.
    • Pull the cover out directly toward the left.
Bryan Chung
437 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 113
All Time: 3,704
