Introduction
This guide will show you how to:
- Remove the battery
- Remove the front panel
- Replace the speaker
Hold the phone with the back facing you.
Press the silver tab down and remove the cover.
Use a plastic opening tool to gently pry the bottom cover loose.
Pull the cover from the front of the phone after the back is loose.
Gently pry off the side casings from the top.
You will not need to remove the sides on the bottom.
Use a plastic opening tool to detach the securing clips holding the the front panel in place.
Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
