Installing Blackberry Curve 8320 Speaker
  1. Installing Blackberry Curve 8320 Speaker, Battery: step 1, image 1 of 2 Installing Blackberry Curve 8320 Speaker, Battery: step 1, image 2 of 2
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Installing Blackberry Curve 8320 Speaker: step 2, image 1 of 1
    • Pull up on the top edge of the battery to remove it.
  3. Installing Blackberry Curve 8320 Speaker, Front Panel: step 3, image 1 of 3 Installing Blackberry Curve 8320 Speaker, Front Panel: step 3, image 2 of 3 Installing Blackberry Curve 8320 Speaker, Front Panel: step 3, image 3 of 3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Installing Blackberry Curve 8320 Speaker: step 4, image 1 of 2 Installing Blackberry Curve 8320 Speaker: step 4, image 2 of 2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Installing Blackberry Curve 8320 Speaker: step 5, image 1 of 2 Installing Blackberry Curve 8320 Speaker: step 5, image 2 of 2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Installing Blackberry Curve 8320 Speaker: step 6, image 1 of 1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Installing Blackberry Curve 8320 Speaker: step 7, image 1 of 1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  8. Installing Blackberry Curve 8320 Speaker, Speaker: step 8, image 1 of 3 Installing Blackberry Curve 8320 Speaker, Speaker: step 8, image 2 of 3 Installing Blackberry Curve 8320 Speaker, Speaker: step 8, image 3 of 3
    • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
    • The screws are 6mm long.
  9. Installing Blackberry Curve 8320 Speaker: step 9, image 1 of 2 Installing Blackberry Curve 8320 Speaker: step 9, image 2 of 2
    • After the bottom two screws have been removed the side casings can be removed.
  10. Installing Blackberry Curve 8320 Speaker: step 10, image 1 of 3 Installing Blackberry Curve 8320 Speaker: step 10, image 2 of 3 Installing Blackberry Curve 8320 Speaker: step 10, image 3 of 3
    • Remove the back case.
    • The speaker is located on the back case.
Christopher Aiello
89 Reputation
5 Guides authored
Cal Poly, Team 3-6, Regan Fall 2011 Member of Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,004
