Installing Blackberry Curve 8320 LCD Screen
  1. Installing Blackberry Curve 8320 LCD Screen, Battery: step 1, image 1 of 2 Installing Blackberry Curve 8320 LCD Screen, Battery: step 1, image 2 of 2
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Installing Blackberry Curve 8320 LCD Screen: step 2, image 1 of 1
    • Pull up on the top edge of the battery to remove it.
  3. Installing Blackberry Curve 8320 LCD Screen, Front Panel: step 3, image 1 of 3 Installing Blackberry Curve 8320 LCD Screen, Front Panel: step 3, image 2 of 3 Installing Blackberry Curve 8320 LCD Screen, Front Panel: step 3, image 3 of 3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Installing Blackberry Curve 8320 LCD Screen: step 4, image 1 of 2 Installing Blackberry Curve 8320 LCD Screen: step 4, image 2 of 2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Installing Blackberry Curve 8320 LCD Screen: step 5, image 1 of 2 Installing Blackberry Curve 8320 LCD Screen: step 5, image 2 of 2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Installing Blackberry Curve 8320 LCD Screen: step 6, image 1 of 1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Installing Blackberry Curve 8320 LCD Screen: step 7, image 1 of 1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  8. Installing Blackberry Curve 8320 LCD Screen, LCD Screen: step 8, image 1 of 3 Installing Blackberry Curve 8320 LCD Screen, LCD Screen: step 8, image 2 of 3 Installing Blackberry Curve 8320 LCD Screen, LCD Screen: step 8, image 3 of 3
    • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
    • The screws are 6mm long.
  9. Installing Blackberry Curve 8320 LCD Screen: step 9, image 1 of 2 Installing Blackberry Curve 8320 LCD Screen: step 9, image 2 of 2
    • After the bottom two screws have been removed the side casings can be removed.
  10. Installing Blackberry Curve 8320 LCD Screen: step 10, image 1 of 3 Installing Blackberry Curve 8320 LCD Screen: step 10, image 2 of 3 Installing Blackberry Curve 8320 LCD Screen: step 10, image 3 of 3
    • When all four screws are removed, the keyboard frame, screen housing, screen, and back casing can be separated.
    • The screen frame hooks on to the top of the motherboard with a small tab on the motherboard.
  11. Installing Blackberry Curve 8320 LCD Screen: step 11, image 1 of 1
    • Place the motherboard on a flat surface with the LCD screen face up.
  12. Installing Blackberry Curve 8320 LCD Screen: step 12, image 1 of 3 Installing Blackberry Curve 8320 LCD Screen: step 12, image 2 of 3 Installing Blackberry Curve 8320 LCD Screen: step 12, image 3 of 3
    • Using a plastic opening tool, gently pull the connector directly up from the motherboard.
    • Remove the LCD screen from the motherboard.
    • The screen is attached to the motherboard with adhesive.
Christopher Aiello
89 Reputation
5 Guides authored
Cal Poly, Team 3-6, Regan Fall 2011 Member of Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 2,404
