Installing Blackberry Bold 9650 Buzzer-Loundspeaker
  1. Installing Blackberry Bold 9650 Buzzer-Loundspeaker, Battery: step 1, image 1 of 2 Installing Blackberry Bold 9650 Buzzer-Loundspeaker, Battery: step 1, image 2 of 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Installing Blackberry Bold 9650 Buzzer-Loundspeaker: step 2, image 1 of 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Installing Blackberry Bold 9650 Buzzer-Loundspeaker, SIM Card: step 3, image 1 of 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Installing Blackberry Bold 9650 Buzzer-Loundspeaker: step 4, image 1 of 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Installing Blackberry Bold 9650 Buzzer-Loundspeaker, Back Chassis: step 5, image 1 of 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Installing Blackberry Bold 9650 Buzzer-Loundspeaker: step 6, image 1 of 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Installing Blackberry Bold 9650 Buzzer-Loundspeaker: step 7, image 1 of 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Installing Blackberry Bold 9650 Buzzer-Loundspeaker: step 8, image 1 of 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Installing Blackberry Bold 9650 Buzzer-Loundspeaker, Buzzer-Loundspeaker: step 9, image 1 of 1
    • Use a plastic pry tool to remove the speaker.
    • Be careful removing removing the speaker as the plastic frame around the speaker is fragile.
Ryan
696 Reputation
11 Guides authored
Clemson, Team 2-5, Benson Spring 2012 Member of Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 3,977
