Blackberry Bold 9650 Back Chassis Replacement
  1. Blackberry Bold 9650 Back Chassis Replacement, Battery: step 1, image 1 of 2 Blackberry Bold 9650 Back Chassis Replacement, Battery: step 1, image 2 of 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Back Chassis Replacement: step 2, image 1 of 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Back Chassis Replacement, SIM Card: step 3, image 1 of 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Back Chassis Replacement: step 4, image 1 of 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Back Chassis Replacement, Back Chassis: step 5, image 1 of 1
    • Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
  6. Blackberry Bold 9650 Back Chassis Replacement: step 6, image 1 of 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Back Chassis Replacement: step 7, image 1 of 1
    • Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
  8. Blackberry Bold 9650 Back Chassis Replacement: step 8, image 1 of 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
Ryan
696 Reputation
11 Guides authored
Clemson, Team 2-5, Benson Spring 2012 Member of Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 3,174
