BlackMagic Hyperdeck Studio Mini Fan Replacement
Video Overview
  1. BlackMagic Hyperdeck Studio Mini Fan Replacement, Unscrew the Outer Case: step 1, image 1 of 1
    • 4 Screws on each side
  2. BlackMagic Hyperdeck Studio Mini Fan Replacement, Remove Fan: step 2, image 1 of 1
    • 2 - Screws
    • 1 - Pull cable
  3. BlackMagic Hyperdeck Studio Mini Fan Replacement, Cut Off Connector from both the old and new fan: step 3, image 1 of 1
    • Leave some length to solder with and to reach connector on main board.
  4. BlackMagic Hyperdeck Studio Mini Fan Replacement, Prep Fan Wires and Connector Wires: step 4, image 1 of 1
    • Strip Wires, Tin Wires, and prep by adding heat shrink tubing on wires (before shrinking).
  5. BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: step 5, image 1 of 3 BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: step 5, image 2 of 3 BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: step 5, image 3 of 3
    • Solder the new fan to the old connector using the following pinout.
    • Adjust heat shrink tubing so it covers the solder joints and use heat gun to shrink tubing.
  6. BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-assemble fan to device with fan label facing out: step 6, image 1 of 2 BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-assemble fan to device with fan label facing out: step 6, image 2 of 2
    • Re-assemble fan to device with fan label facing out.
    • OPTIONAL - Use Small Round Nose Pliers to break off case grill to make fan even quieter.
  7. BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-Assemble Case: step 8, image 1 of 1
    • Re-Assemble case.
Kevin Krautle
508 Reputation
2 Guides authored
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 57
All Time: 4,185
