Introduction
BlackMagic Hyperdeck Studio Mini has a very loud fan that can be replaced to make the quieter.
WARNING - THIS WILL VOID YOUR WARRANTY!
Video Overview
Leave some length to solder with and to reach connector on main board.
Strip Wires, Tin Wires, and prep by adding heat shrink tubing on wires (before shrinking).
Solder the new fan to the old connector using the following pinout.
Adjust heat shrink tubing so it covers the solder joints and use heat gun to shrink tubing.
Re-assemble fan to device with fan label facing out.
OPTIONAL - Use Small Round Nose Pliers to break off case grill to make fan even quieter.
3 other people completed this guide.
5 Comments
Just replaced mine monitoring the temperature now. As @tberntson mentioned, the fan comes with some Skotchlok connectors and no soldering even required. I can’t believe how quiet the new fan is. Complete night and day difference. Kevin, thanks so much for sharing this.
Thank you so much! I soldered it and it works great! So silent now that I can´t hear it at all!
