BlackMagic ATEM Television Studio Quiet Fan Upgrade
Video Overview
  1. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Unscrew the Outer Case: step 1, image 1 of 1
    • 2 Screws on each side
    • 6 Screws on top
  2. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Remove Fans: step 2, image 1 of 1
    • Remove Both Fans
    • 2 - Screws each
    • 1 - Pull cable each
  3. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Cut Off Connector from both the olds and new fans: step 3, image 1 of 1
    • Leave some length to solder with and to reach connector on main board.
  4. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Prep Fan Wires and Connector Wires: step 4, image 1 of 1
    • Strip Wires, Tin Wires, and prep by adding heat shrink tubing on wires (before shrinking).
  5. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Solder Connecter to Fan: step 5, image 1 of 3 BlackMagic ATEM Television Studio Quiet Fan Upgrade, Solder Connecter to Fan: step 5, image 2 of 3 BlackMagic ATEM Television Studio Quiet Fan Upgrade, Solder Connecter to Fan: step 5, image 3 of 3
    • For Both Fans
    • Solder the new fan to the old connector using the following pinout.
    • Adjust heat shrink tubing so it covers the solder joints and use heat gun to shrink tubing.
  6. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Re-assemble fans to device with fan label facing out: step 6, image 1 of 1
    • Re-assemble fans to device with fan label facing out.
  7. BlackMagic ATEM Television Studio Quiet Fan Upgrade, OPTIONAL - Use Small Round Nose Pliers to break off case grill to make fan even quieter: step 7, image 1 of 1
    • OPTIONAL - Use Small Round Nose Pliers to break off case grill to make fan even quieter.
  8. BlackMagic ATEM Television Studio Quiet Fan Upgrade, Re-Assemble Case: step 8, image 1 of 1
    • Re-Assemble Case
Kevin Krautle
508 Reputation
2 Guides authored
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 54
All Time: 7,242
