BlackBerry Storm 9530 Logic/Motherboard Replacement
  1. BlackBerry Storm 9530 Logic/Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
  2. BlackBerry Storm 9530 Logic/Motherboard Replacement: step 2, image 1 of 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: step 2, image 2 of 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: step 2, image 3 of 3
    • Turn your Storm where the battery door is facing up.
    • Remove the battery door.
    • Remove the battery.
  3. BlackBerry Storm 9530 Logic/Motherboard Replacement: step 3, image 1 of 1
    • Remove the two hex screws as shown by the SIM card slot.
  4. BlackBerry Storm 9530 Logic/Motherboard Replacement: step 4, image 1 of 2 BlackBerry Storm 9530 Logic/Motherboard Replacement: step 4, image 2 of 2
    • Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool.
    • Remove the two hex screws underneath it.
  5. BlackBerry Storm 9530 Logic/Motherboard Replacement: step 5, image 1 of 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: step 5, image 2 of 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: step 5, image 3 of 3
    • Turn the phone over and remove the plastic cover under the buttons as shown.
    • Remove the 2 screws underneath.
  6. BlackBerry Storm 9530 Logic/Motherboard Replacement: step 6, image 1 of 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: step 6, image 2 of 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: step 6, image 3 of 3
    • Go around your device with the plastic pry tool, there a 3 clips on each side of the housing.
    • There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
  7. BlackBerry Storm 9530 Logic/Motherboard Replacement: step 7, image 1 of 1
    • You now have 3 pieces. The rear, mid , & front housing.
  8. BlackBerry Storm 9530 Logic/Motherboard Replacement: step 8, image 1 of 2 BlackBerry Storm 9530 Logic/Motherboard Replacement: step 8, image 2 of 2
    • To remove the screen gently pry up this ribbon cable with a pry tool.
  9. BlackBerry Storm 9530 Logic/Motherboard Replacement: step 9, image 1 of 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: step 9, image 2 of 3 BlackBerry Storm 9530 Logic/Motherboard Replacement: step 9, image 3 of 3
    • To remove the main board from the mid housing disconnect the ribbon cable as pictured.
    • Now follow in reverse order for reassembly!
Josh Forester
2,502 Reputation
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 9,563
