Shop the Holiday Gift Guide
BlackBerry PlayBook Back Panel Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
7
All Time:
295
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. BlackBerry PlayBook Back Panel Replacement, Remove Back Panel: step 1, image 1 of 2 BlackBerry PlayBook Back Panel Replacement, Remove Back Panel: step 1, image 2 of 2
      • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
      • There are clips that need to be released on all four sides of the device.
      • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
      Ask FixBot
Author
with
Michael Granneman
561 Reputation
1 Guide authored
Cal Poly, Team 14-27, Maness Fall 2014 Member of Cal Poly, Team 14-27, Maness Fall 2014
CPSU-MANESS-F14S14G27
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 295
