Installing BlackBerry Curve 8520 Screen
  1. Installing BlackBerry Curve 8520 Screen, Battery: step 1, image 1 of 2 Installing BlackBerry Curve 8520 Screen, Battery: step 1, image 2 of 2
    • Place the phone on a flat surface with the screen facing down.
    • Remove the plastic backplate by pulling up on the bottom of the cover.
  2. Installing BlackBerry Curve 8520 Screen: step 2, image 1 of 1
    • Remove the battery by pulling up from the top of the battery.
  3. Installing BlackBerry Curve 8520 Screen, Keypad: step 3, image 1 of 2 Installing BlackBerry Curve 8520 Screen, Keypad: step 3, image 2 of 2
    • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
    • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
  4. Installing BlackBerry Curve 8520 Screen: step 4, image 1 of 2 Installing BlackBerry Curve 8520 Screen: step 4, image 2 of 2
    • Flip the phone over so the keyboard faces up.
    • Insert a plastic spudger into the screen where speaker resides.
    • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
    • Gently lift up plastic screen cover until screen cover separates from screen.
    • Continue until screen cover is completely removed.
  5. Installing BlackBerry Curve 8520 Screen: step 5, image 1 of 3 Installing BlackBerry Curve 8520 Screen: step 5, image 2 of 3 Installing BlackBerry Curve 8520 Screen: step 5, image 3 of 3
    • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
    • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
  6. Installing BlackBerry Curve 8520 Screen: step 6, image 1 of 2 Installing BlackBerry Curve 8520 Screen: step 6, image 2 of 2
    • The keyboard should slide off of the phone now that the plastic siding has been removed.
  7. Installing BlackBerry Curve 8520 Screen, Screen: step 7, image 1 of 3 Installing BlackBerry Curve 8520 Screen, Screen: step 7, image 2 of 3 Installing BlackBerry Curve 8520 Screen, Screen: step 7, image 3 of 3
    • To detach the screen, there are two screws at the top of the phone to be removed. Use the T6 Torx Screwdriver to remove the screws.
    • There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone.
    • Note: When reassembling, the ribbon should be reattached before replacing the top screws.
  8. Installing BlackBerry Curve 8520 Screen: step 8, image 1 of 3 Installing BlackBerry Curve 8520 Screen: step 8, image 2 of 3 Installing BlackBerry Curve 8520 Screen: step 8, image 3 of 3
    • There are two clips on each side of the phone. Insert a plastic spudger between the clips and the screen.
    • Use pressure to unlatch the screen from the clips.
    • Now that these clips have been undone, the screen should lift up easily.
Michael Labdon
259 Reputation
1 Guide authored
Cal Poly, Team 15-13, Regan Spring 2011 Member of Cal Poly, Team 15-13, Regan Spring 2011
CPSU-REGAN-S11S15G13
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 7,889
