BlackBerry Curve 8310 Lens Replacement
  1. BlackBerry Curve 8310 Lens Replacement, Battery: step 1, image 1 of 1
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. BlackBerry Curve 8310 Lens Replacement: step 2, image 1 of 1
    • Pry from the top of the battery to pull it out.
  3. BlackBerry Curve 8310 Lens Replacement, Lens: step 3, image 1 of 1
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. BlackBerry Curve 8310 Lens Replacement: step 4, image 1 of 1
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. BlackBerry Curve 8310 Lens Replacement: step 5, image 1 of 1
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. BlackBerry Curve 8310 Lens Replacement: step 6, image 1 of 3 BlackBerry Curve 8310 Lens Replacement: step 6, image 2 of 3 BlackBerry Curve 8310 Lens Replacement: step 6, image 3 of 3
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
Sean Willis
229 Reputation
5 Guides authored
Cal Poly, Team 10-32, Amido Winter 2012 Member of Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 14
All Time: 988
