Introduction
This guide shows how to remove the side button used to browse through the menus on the RIM BlackBerry 7290.
Apply pressure to the lock button on the back of the device.
Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
Locate groove along the right side of the battery compartment.
Remove battery by prying between the battery and the groove.
Lift the SIM card holder up.
Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
Locate the four screws along the perimeter of the back casing.
Remove the four top screws using a T-6 torx screwdriver.
Locate two screws within the lower edge of the battery compartment.
Remove the two bottom screws using a T-6 torx screwdriver.
Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
With both of the bottom clips unhooked, lift the bottom portion of the phone and slide it upwards (towards your fingers) to detach the back cover from the front cover.
Using a T-6 screwdriver, remove the screw located on top of the phone.
After the screw has been removed, carefully lift the side button brace to reveal the side button.
