Shop the Holiday Gift Guide
Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
56
All Time:
472
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show how to disassemble the Black and Decker The ShellBaker Meal and Desert Maker G400/G450, as well as explain the electrical schematic of the appliance. The ShellBaker is a simple device used to bake dough into shell shapes, so the main problem that can occur with the ShellBaker is that it doesn't heat properly. This device will explain how to take apart the ShellBaker to reach the heating mechanism so that it can be fixed. The ShellBaker does not have an on/off switch so make sure to unplug the appliance while repairing it.
    1. Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly, Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 1, image 1 of 1
      • Make sure to unplug the ShellBaker and wait for it to cool before disassembly.
      • If there is a non-stick pan, make sure to take it out and set it aside.
      Ask FixBot
    2. Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 2, image 1 of 3 Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 2, image 2 of 3 Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 2, image 3 of 3
      • Open the ShellBaker such that the outdented pan surface is facing up, and the handle is facing toward you.
      • Remove the two 12.7mm screws on either side of the handle using a Phillips #2 screwdriver.
      • Remove the handle from the ShellBaker.
      Ask FixBot
    3. Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 3, image 1 of 2 Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 3, image 2 of 2
      • Orient the ShellBaker so that the back end is facing you.
      • Remove the 19.1 mm screw located above the bottom stand using a TR25 Torx Security screwdriver.
      • The top of the lid should now be detached from the top part of the pan and the circuitry on the top should be revealed.
      Ask FixBot
    4. Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 4, image 1 of 2 Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 4, image 2 of 2
      • Flip the ShellBaker over so that you are looking at the bottom of it.
      • Remove the two 12.7mm screws on the end opposite the handle that attach the bottom stand to the base of the machine with a Phillips #2 screwdriver.
      Ask FixBot
    5. Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 5, image 1 of 2 Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 5, image 2 of 2
      • Remove the bottom stand from the base of the machine.
      • Remove the two 12.7mm screws on the clip that keeps the power strip in place using a Phillips #2 screwdriver.
      • Remove the clip to release the power strip.
      Ask FixBot
    6. Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 6, image 1 of 2 Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 6, image 2 of 2
      • Remove the two 12.7mm screws revealed in the bottom stand of the machine using a Phillips #2 screwdriver.
      Ask FixBot
    7. Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 7, image 1 of 2 Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 7, image 2 of 2
      • Keeping the machine face down, remove the 19.1 mm screw in the center of the base using a TR25 Torx Security screwdriver (also known as Torx Tamper Proof screwdriver).
      • This screw may require a lot of force to unscrew.
      Ask FixBot
    8. Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 8, image 1 of 1
      • The lid and base of the ShellBaker should now detach and you should be able to view the circuits of the machine on the top and bottom.
      Ask FixBot
    9. Black and Decker The ShellBaker Meal and Dessert Maker G400 Disassembly: step 9, image 1 of 1
      • Circuit Diagram for the ShellBaker
      Ask FixBot
Author
with
Megan Yi
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 56
All Time: 472
