Black and Decker LDX172C Battery Charge Port Replacement
  1. Black and Decker LDX172C Battery Charge Port Replacement, Battery Charge Port: step 1, image 1 of 1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Battery Charge Port Replacement: step 2, image 1 of 1
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Battery Charge Port Replacement: step 3, image 1 of 1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the battery charging port in the base of the drill.
  4. Black and Decker LDX172C Battery Charge Port Replacement: step 4, image 1 of 1
    • Remember that the battery may still have a charge. To avoid electrical shock, it is a good idea to disconnect the battery before modifying any connections on the charging port. You can find how to disconnect the battery here
    • Remove the soldered wire connections as marked.
    • Re-solder the wire connections to the new charge port and insert the charge port back into its proper location.
    • Repeat steps in reverse to reassemble.
2 other people completed this guide.
Eric Miessen
182 Reputation
1 Guide authored
IUPUI, Team 3-3, Wilson Spring 2016 Member of IUPUI, Team 3-3, Wilson Spring 2016
IUPUI-WILSON-S16S3G3
4 Members
6 Guides authored
One Comment
Hi where can I get the replacement charge port from. Thanks
adam mellor - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 32
All Time: 2,472
