Introduction
This guide will take you through the process of replacing the impeller on the Black and Decker BV2500 Type 4.
Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
Using your hands, remove the blower tube and clamshell.
To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver.
Using your hands, lift off the side of the orange casing with the screws facing you.
Locate the fan.
Unscrew the 9/16" cap and nut (in the middle of the fan) with the ratcheting socket wrench.
