Bissell OptiClean Cyclonic Vacuum Filter Replacements
  1. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: step 1, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: step 1, image 2 of 2
    • Grab hold of both the flex hose handle and the extension wand.
    • Pull straight out to detach the handle from the extension wand.
  2. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 2, image 1 of 1
    • Locate the lock clip on the other end of the flex hose.
  3. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 3, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 3, image 2 of 2
    • Hold down the lock clip to unlock the flex hose from the vacuum.
    • Remove the flex hose from the vacuum.
  4. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: step 4, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: step 4, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: step 4, image 3 of 3
    • After removing hose, place vacuum on back and unclip the top compartment.
    • Open the compartment.
    • Pull the dirt collection box out of the vacuum.
  5. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 5, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 5, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 5, image 3 of 3
    • Place dirt collection box to the side.
    • Locate the Pre-Motor Filter.
    • Pull the filter out by grabbing the pull tab on top.
  6. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 6, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 6, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 6, image 3 of 3
    • Turn vacuum around and locate the filter cover on the bottom.
    • Place fingers in the opening and pull off the filter cover.
    • Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
  7. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 7, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 7, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 7, image 3 of 3
    • Take filter out to clean or replace.
    • To clean Dirt Collection Box, unlatch lid and take off.
  8. Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 8, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 8, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: step 8, image 3 of 3
    • Flip Dirt Collection Box over and locate the push tab.
    • Push the Dirt Cup HEPA Media Filter up to take it off.
    • Picture 3 Shows all the filters taken out of the vacuum.
Austin Marshall
130 Reputation
1 Guide authored
Cal Poly, Team S12-G1, Banghart Winter 2018 Member of Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 875
