Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement
  1. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement, Flex Hose with Handle: step 1, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement, Flex Hose with Handle: step 1, image 2 of 2
    • Grab hold of both the flex hose handle and the extension wand.
    • Pull straight out to detach the handle from the extension wand.
  2. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 2, image 1 of 1
    • Locate the lock clip on the other end of the flex hose.
  3. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 3, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 3, image 2 of 2
    • Hold down the lock clip to unlock the flex hose from the vacuum.
    • Remove the flex hose from the vacuum.
  4. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement, Filters: step 4, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement, Filters: step 4, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement, Filters: step 4, image 3 of 3
    • After removing hose, place vacuum on back and unclip the top compartment.
    • Open the compartment.
    • Pull the dirt collection box out of the vacuum.
  5. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 5, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 5, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 5, image 3 of 3
    • Place dirt collection box to the side.
    • Locate the Pre-Motor Filter.
    • Pull the filter out by grabbing the pull tab on top.
  6. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 6, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 6, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 6, image 3 of 3
    • Turn vacuum around and locate the filter cover on the bottom.
    • Place fingers in the opening and pull off the filter cover.
    • Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
  7. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 7, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 7, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 7, image 3 of 3
    • Take filter out to clean or replace.
    • To clean Dirt Collection Box, unlatch lid and take off.
  8. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 8, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 8, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 8, image 3 of 3
    • Flip Dirt Collection Box over and locate the push tab.
    • Push the Dirt Cup HEPA Media Filter up to take it off.
    • Picture 3 Shows all the filters taken out of the vacuum.
  9. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement, Motor and Circuit Board: step 9, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement, Motor and Circuit Board: step 9, image 2 of 2
    • Unscrew the two screws underneath the dirt collection box inside the vacuum.
  10. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 10, image 1 of 1
    • Flip over vacuum.
  11. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 11, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 11, image 2 of 2
    • Unscrew both screws on the bottom of the handle.
  12. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 12, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 12, image 2 of 2
    • Unscrew both screws near the wheels.
  13. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 13, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 13, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 13, image 3 of 3
    • Flip over vacuum.
    • Gently lift off top.
    • Do not try to take off completely. There are still wires attached to the hull.
  14. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 14, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 14, image 2 of 2
    • Locate the circuit board.
  15. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 15, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 15, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 15, image 3 of 3
    • Unplug each orange plug.
    • Make sure you remember which orange plug goes where!
  16. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 16, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 16, image 2 of 2
    • Unplug the red wires. The wires may be a little difficult to take off. If they are, you may use a pair of pliers to pull the wires off.
    • Make sure not to wiggle the wires, as that may break the metal holding them.
  17. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 17, image 1 of 1
    • Remove the top.
  18. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 18, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 18, image 2 of 2
    • Unscrew the top two screws on the vacuum.
  19. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 19, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 19, image 2 of 2
    • Unscrew the back two scews.
  20. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 20, image 1 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 20, image 2 of 3 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 20, image 3 of 3
    • Lift motor and move it over the gain access to the spool.
    • Unscrew the screw on the spool.
    • Remove the plastic circle.
  21. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 21, image 1 of 1
    • Remove the motor.
    • And you are done!
  22. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement, Cord w/ Reel: step 22, image 1 of 1
    • Grab hold of the cord reel and cord. Make sure cord is retracted all the way in.
  23. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 23, image 1 of 1
    • Pull on cord reel to remove it. You should hear a click indicating it has detached from the area indicated in the picture.
  24. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 24, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 24, image 2 of 2
    • Use screwdriver to remove screws from either side of the cord.
  25. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 25, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 25, image 2 of 2
    • Flip over vacuum.
    • Remove grate that holds the power cord as pictured.
  26. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 26, image 1 of 2 Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 26, image 2 of 2
    • Grab hold of head of power cord and pull up.
    • Power cord should disconnect from vacuum body as pictured.
  27. Bissell OptiClean Cyclonic Vacuum Cord w/ Reel Replacement: step 27, image 1 of 1
    • Remove the cord reel and cord from the vacuum body.
Rianne Paracuelles
163 Reputation
1 Guide authored
Cal Poly, Team S12-G1, Banghart Winter 2018 Member of Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 Members
5 Guides authored
1 Guide Comment
- very good guide
Austin Marshall - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 780
