Bissell Featherweight Lightweight Switch Replacement
    1. Bissell Featherweight Lightweight Switch Replacement, Power Switch: step 1, image 1 of 1
      • Separate the filter from the electronics housing by pressing the grey latch.
      Ask FixBot
    2. Bissell Featherweight Lightweight Switch Replacement: step 2, image 1 of 1
      • Unscrew the electronic housing screws using a Phillips #00 screwdriver.
      • Remove the front panel.
      Ask FixBot
    3. Bissell Featherweight Lightweight Switch Replacement: step 3, image 1 of 2 Bissell Featherweight Lightweight Switch Replacement: step 3, image 2 of 2
      • Identify the switch within the internal electronics.
      • The switch is connected to the rest of the circuit via two terminals with one terminal covered by a blue heat shrink tube.
      Ask FixBot
    4. Bissell Featherweight Lightweight Switch Replacement: step 4, image 1 of 2 Bissell Featherweight Lightweight Switch Replacement: step 4, image 2 of 2
      • Remove the switch from the clasps. Use a spudger to push down on the metal tab and pull the switch terminal away.
      • When removing the blue heat shrink side just pull the heat shrink below the metal terminal.
      Ask FixBot
    5. Bissell Featherweight Lightweight Switch Replacement: step 5, image 1 of 1
      • Reattach the new switch.
      • It should just slide in when the terminal and clasps are aligned.
      Ask FixBot
    6. Bissell Featherweight Lightweight Switch Replacement: step 6, image 1 of 1
      • Position the switch in the plastic slot in the housing.
      Ask FixBot
    7. Bissell Featherweight Lightweight Switch Replacement: step 7, image 1 of 1
      • Reattach the outer panel of the electronic housing.
      • Ensure that the switch is flush against both sides.
      Ask FixBot
    8. Bissell Featherweight Lightweight Switch Replacement: step 8, image 1 of 1
      • Reattach the electronics to the filter component of the vacuum and test the switch by powering the vacuum and turning it on and off.
      Ask FixBot
Finish Line
Joshua Antony
157 Reputation
1 Guide authored
UC Davis, Team 1-8, Morris Fall 2025 Member of UC Davis, Team 1-8, Morris Fall 2025
UCD-MORRIS-F25S1G8
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 84
All Time: 258
