Introduction
This guide for the Bissell CleanView Compact 3508 will give you step-by-step instructions to replace the motor at the base of your vacuum. For this particular product, the motor and power supply are one assembly. This guide will bring you full access to both. You may need to replace this part if all other solutions fail to bring your vacuum to functioning condition.
With the vacuum in an upright position, press the latch on the rear of the spine to remove the handle from the vacuum.
Push the button on the canister to remove it from the spine.
Set the canister to the side.
