Bissell CleanView Compact 3508 Brush Roll Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
63
All Time:
387
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 - 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide for the Bissell CleanView Compact 3508 will give you step-by-step instructions to replace the roller brush at the base of your vacuum. This is the brush that spins to pick up dirt as you move the vacuum. If you are experiencing a stuck roller brush, consult this troubleshooting guide before replacing the part.
Tools
    1. Bissell CleanView Compact 3508 Brush Roll Replacement, Brush Roll Cover: step 1, image 1 of 3 Bissell CleanView Compact 3508 Brush Roll Replacement, Brush Roll Cover: step 1, image 2 of 3 Bissell CleanView Compact 3508 Brush Roll Replacement, Brush Roll Cover: step 1, image 3 of 3
      • With the vacuum in an upright position, press the latch on the rear of the spine to remove the handle from the vacuum.
      Ask FixBot
    2. Bissell CleanView Compact 3508 Brush Roll Replacement: step 2, image 1 of 2 Bissell CleanView Compact 3508 Brush Roll Replacement: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the five 20.7 mm screws on the underside of the brush roll cover.
      Ask FixBot
    3. Bissell CleanView Compact 3508 Brush Roll Replacement: step 3, image 1 of 3 Bissell CleanView Compact 3508 Brush Roll Replacement: step 3, image 2 of 3 Bissell CleanView Compact 3508 Brush Roll Replacement: step 3, image 3 of 3
      • Use a pry tool or flathead screwdriver to disengage the two retaining clips securing the brush roll cover.
      • Remove the brush roll cover.
      Ask FixBot
    1. Bissell CleanView Compact 3508 Brush Roll Replacement, Brush Roll: step 4, image 1 of 3 Bissell CleanView Compact 3508 Brush Roll Replacement, Brush Roll: step 4, image 2 of 3 Bissell CleanView Compact 3508 Brush Roll Replacement, Brush Roll: step 4, image 3 of 3
      • Pull the roller brush out of the cavity.
      • Remove the belt from around the brush roller.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 63
All Time: 387
