Bicycle Freewheel Replacement
  1. Bicycle Freewheel Replacement, Freewheel: step 1, image 1 of 3 Bicycle Freewheel Replacement, Freewheel: step 1, image 2 of 3 Bicycle Freewheel Replacement, Freewheel: step 1, image 3 of 3
    • Before you begin, remove the rear wheel from your bike.
    • Place the freewheel removal tool onto the notches of the freewheel.
  2. Bicycle Freewheel Replacement: step 2, image 1 of 1
    • Use an adjustable wrench to turn the freewheel removal tool counter-clockwise to loosen the freewheel.
  3. Bicycle Freewheel Replacement: step 3, image 1 of 3 Bicycle Freewheel Replacement: step 3, image 2 of 3 Bicycle Freewheel Replacement: step 3, image 3 of 3
    • When it's loose, remove the freewheel by hand.
  4. Bicycle Freewheel Replacement: step 4, image 1 of 1
    • Carefully examine the hub threads for any signs of damage or wear, such as cross-threading or debris.
    • Before installing the new freewheel, apply a light coat of grease or anti-seize lubricant to prevent future issues and ensure smooth installation.
  5. Bicycle Freewheel Replacement: step 5, image 1 of 2 Bicycle Freewheel Replacement: step 5, image 2 of 2
    • Install the new freewheel by spinning it with your hand clockwise until it is snug.
    • You should not feel any tension as this is a sign of cross-threading.
After following this guide your new freewheel should be installed.
David Hanna
122 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 82
All Time: 615
