Separate Chain for Disassembly
  1. Separate Chain for Disassembly, Bike Chain (Disassembly): step 1, image 1 of 2 Separate Chain for Disassembly, Bike Chain (Disassembly): step 1, image 2 of 2
    • Slide the chain cutting tool onto the desired link.
    • Align the push pin of the tool with the pin on the chain, and tighten the tool until the pin protrudes out the other side without falling all the way out.
  2. Separate Chain for Disassembly: step 2, image 1 of 1
    • Stop pushing the pin out when it is just held in by the outer link, so it doesn't fall all the way out. You will still be able to separate the links.
    • Repeat the previous step to take off sections of links.
aaron thielk
1,882 Reputation
5 Guides authored
Cal Poly, Team 5-13, Maness Fall 2010 Member of Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Members
17 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 7,972
