Bicycle chainring replacement
  1. Bicycle chainring replacement, Chainring: step 1, image 1 of 1
    • Unscrew both nuts on opposite sides of the rear wheel with the 15 mm wrench until the wheel loosens from the bike frame.
    • Loosen the nuts with the 15 mm wrench and continue unscrewing the nuts with your hands.
    • Push the rear wheel forward until enough slack is given on the chain.
  2. Bicycle chainring replacement: step 2, image 1 of 2 Bicycle chainring replacement: step 2, image 2 of 2
    • With the slack previously made, remove the chain off the chainring.
    • Touching the chain isn't dangerous, but it will be dirty.
  3. Bicycle chainring replacement: step 3, image 1 of 2 Bicycle chainring replacement: step 3, image 2 of 2
    • Locate chainring, the gear connected to the pedals.
    • Place the spanner tool on the backside of the 6.5 mm chainring bolt. The spanner will be used to keep the bolts in place while unscrewing them on the opposite sides.
    • On the chainring there will be one bolt facing the opposite direction, usually the bolt blocked by the pedal. Adjust for this by swapping use of the hex key and spanner tool.
  4. Bicycle chainring replacement: step 4, image 1 of 1
    • With the spanner tool on one side of the chainring, use a 5 mm hex key to remove the chainring bolts on the opposite side.
    • Repeat with the rest of the bolts.
  5. Bicycle chainring replacement: step 5, image 1 of 1
    • Use clean paper towels to wipe off the chainring bolts. Make sure to wipe off all the dirt and grease you can.
    • Clean thoroughly within the threads.
  6. Bicycle chainring replacement: step 6, image 1 of 1
    • Now that the chainring bolts are clean, apply a pea-sized amount of grease to each bolt.
  7. Bicycle chainring replacement: step 7, image 1 of 1
    • Use your fingers to evenly spread a coat the grease around the entire bolt.
    • If the chainring bolts contain rust, it is recommended to replace the bolts with a new set.
6 other people completed this guide.
Jeffrey Tang
391 Reputation
1 Guide authored
Cal Poly, Team 23-5, Green Winter 2015 Member of Cal Poly, Team 23-5, Green Winter 2015
CPSU-GREEN-W15S23G5
4 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 3,398
