Bicycle Tire Inner Tube Replacement
  1. Bicycle Tire Inner Tube Replacement, Rear Wheel: step 1, image 1 of 2 Bicycle Tire Inner Tube Replacement, Rear Wheel: step 1, image 2 of 2
    • Flip the quick release lever on the wheel.
  2. Bicycle Tire Inner Tube Replacement: step 2, image 1 of 1
    • Squeeze the brake arms together and lift the brake cable from the caliper arms.
  3. Bicycle Tire Inner Tube Replacement: step 3, image 1 of 1
    • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
  4. Bicycle Tire Inner Tube Replacement, Inner Tube: step 4, image 1 of 1
  5. Bicycle Tire Inner Tube Replacement: step 5, image 1 of 1
  6. Bicycle Tire Inner Tube Replacement: step 6, image 1 of 1
    • Press the valve core while applying pressure to the tire to deflate the tire.
  7. Bicycle Tire Inner Tube Replacement: step 7, image 1 of 2 Bicycle Tire Inner Tube Replacement: step 7, image 2 of 2
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
  8. Bicycle Tire Inner Tube Replacement: step 8, image 1 of 1
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
Brett Hartt
128,087 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
138 Members
17,679 Guides authored
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 58
All Time: 10,893
