Introduction
In this guide, we are replacing the rear shifting cable on a bike with a friction-based shifter. This cable connects the shifter to the derailleur, allowing you to change gears without manually adjusting the chain on the rear cassette. Common signs that the cable needs replacement include general wear, fraying, or breakage. Exercise caution when handling the old cable, as the wires can be sharp and use the wire cutters carefully to avoid injury. Always ensure the bike is stable and consider wearing gloves to protect your hands.
Adjust the friction shifter so that it is in the position of the hardest gear.
Reinstall the cable housing in its guides if necessary and guide the cable through the rear derailleur cable eye.
Pull the cable through completely.
Ensure the cable is installed correctly underneath the cable securing bolt on the derailleur. It should be in the same place the old cable was secured.
All that's left is to test the repair. Go for a ride and shift gears to see if the repair was successful. If tension in the cable is too loose, the friction shifter in step 1 can be pulled towards the rear wheel to increase tension.
