Bicycle Cassette Replacement
    1. Bicycle Cassette Replacement, Bicycle Cassette: step 1, image 1 of 2 Bicycle Cassette Replacement, Bicycle Cassette: step 1, image 2 of 2
      • Place your wheel on a hard surface with the cassette on your right side.
      • Wrap the chain whip clockwise around the cassette.
      Ask FixBot
    2. Bicycle Cassette Replacement: step 2, image 1 of 3 Bicycle Cassette Replacement: step 2, image 2 of 3 Bicycle Cassette Replacement: step 2, image 3 of 3
      • Insert the cassette lockring tool into the center of the cassette with the lever arm between 7 and 9 o'clock.
      • Holding the chain whip in place with your left hand, apply counterclockwise force on the cassette tool's lever arm.
      • Continue turning the cassette tool until the tool spins freely.
      Ask FixBot
    3. Bicycle Cassette Replacement: step 3, image 1 of 3 Bicycle Cassette Replacement: step 3, image 2 of 3 Bicycle Cassette Replacement: step 3, image 3 of 3
      • Lay the wheel down on a flat surface with the cassette facing upwards.
      • Loosen the cassette lockring by turning it counterclockwise.
      Ask FixBot
    4. Bicycle Cassette Replacement: step 4, image 1 of 3 Bicycle Cassette Replacement: step 4, image 2 of 3 Bicycle Cassette Replacement: step 4, image 3 of 3
      • Remove the cassette lockring.
      • Using both hands, lift the cassette in one piece from the freehub body.
      Ask FixBot
    5. Bicycle Cassette Replacement: step 5, image 1 of 2 Bicycle Cassette Replacement: step 5, image 2 of 2
      • Your cassette may require a spacer to work properly with your freehub. Consult your cassette user's manual to determine your spacer needs.
      • Remove the old freehub body spacer as needed.
      Ask FixBot
    6. Bicycle Cassette Replacement: step 6, image 1 of 3 Bicycle Cassette Replacement: step 6, image 2 of 3 Bicycle Cassette Replacement: step 6, image 3 of 3
      • Locate the small cutout on the bottom of the new cassette.
      • Locate the small ridge on the freehub body.
      • Slide the bottom piece of the new cassette on the freehub body by matching the small cutout with the small ridge.
      Ask FixBot
    7. Bicycle Cassette Replacement: step 7, image 1 of 3 Bicycle Cassette Replacement: step 7, image 2 of 3 Bicycle Cassette Replacement: step 7, image 3 of 3
      • Continue placing smaller cogs on the freehub body by matching the cutouts and ridges.
      • Insert spacers as specified by the cassette user's manual.
      Ask FixBot
    8. Bicycle Cassette Replacement: step 8, image 1 of 3 Bicycle Cassette Replacement: step 8, image 2 of 3 Bicycle Cassette Replacement: step 8, image 3 of 3
      • For the final two cogs, locate the small cutouts and place on top of the already placed cogs by aligning with the top of small ridge on the freehub body.
      • The top two cogs will not fully slide on to the freehub body and require more attention for aligned placement.
      Ask FixBot
    9. Bicycle Cassette Replacement: step 9, image 1 of 2 Bicycle Cassette Replacement: step 9, image 2 of 2
      • Place the cassette lockring onto the top of the final cog.
      • Start threading the lockring clockwise into the freehub by hand.
      Ask FixBot
    10. Bicycle Cassette Replacement: step 10, image 1 of 3 Bicycle Cassette Replacement: step 10, image 2 of 3 Bicycle Cassette Replacement: step 10, image 3 of 3
      • Once the lockring is partially threaded in, insert the cassette lockring tool.
      • Tighten the cassette on the freehub body by turning the lockring tool clockwise.
      • The exact torque to tighten to varies by cassette manufacturer and model. Consult the cassette user's manual.
      • After finishing tightening, check the cassette for play by pulling up on the largest cog. If excess play is present and the cassette has been tightened to specifications, a spacer is likely missing.
      Ask FixBot
Finish Line
Lars Lundqvist
208 Reputation
1 Guide authored
UC Davis, Team 1-5, Morris Spring 2025 Member of UC Davis, Team 1-5, Morris Spring 2025
UCD-MORRIS-S25S1G5
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 44
Past 30 Days: 240
All Time: 1,753
