This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
BenQ BL2700 Power Plug Repair
    1. BenQ BL2700 Power Plug Repair, Power Plug: step 1, image 1 of 2 BenQ BL2700 Power Plug Repair, Power Plug: step 1, image 2 of 2
      • Pry off the frame around the entire perimeter.
      Ask FixBot
    2. BenQ BL2700 Power Plug Repair: step 2, image 1 of 3 BenQ BL2700 Power Plug Repair: step 2, image 2 of 3 BenQ BL2700 Power Plug Repair: step 2, image 3 of 3
      • Unplug the 3 connectors shown in the photo and detach them from the adhesive along the cable.
      Ask FixBot
    3. BenQ BL2700 Power Plug Repair: step 3, image 1 of 2 BenQ BL2700 Power Plug Repair: step 3, image 2 of 2
      • When releasing the cables, a gentle pull is sufficient; the adhesive strips can be reused later.
      • Leave the blue socket attached to the power supply and lift the power supply off the screen panel; if possible, continue working on a different surface and turn the power supply over to do so.
      Ask FixBot
    4. BenQ BL2700 Power Plug Repair: step 4, image 1 of 3 BenQ BL2700 Power Plug Repair: step 4, image 2 of 3 BenQ BL2700 Power Plug Repair: step 4, image 3 of 3
      • Remove the black plastic cover (simply pull it out) and locate the solder points shown.
      Ask FixBot
    5. BenQ BL2700 Power Plug Repair: step 5, image 1 of 2 BenQ BL2700 Power Plug Repair: step 5, image 2 of 2
      • Resolder the 4 shown solder points and, after a short cooling period, reassemble the housing in reverse order.
      Ask FixBot
To reassemble your device, follow the steps in reverse order.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Kevin Pfeiffer
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 63
All Time: 355
