Bem Wireless HL2739B Charging Base Battery Replacement
  1. Bem Wireless HL2739B Charging Base Battery Replacement, Charging Base Battery: step 1, image 1 of 1
    • Peel the rubber cover back from the corner of the auxiliary charging base to reveal the screw.
  2. Bem Wireless HL2739B Charging Base Battery Replacement: step 2, image 1 of 2 Bem Wireless HL2739B Charging Base Battery Replacement: step 2, image 2 of 2
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the auxiliary charging base.
  3. Bem Wireless HL2739B Charging Base Battery Replacement: step 3, image 1 of 1
    • Lift the bottom cover away from the rest of the auxiliary charging base.
    • There are wires connecting the battery and cover to the rest of the auxiliary charging base. Be careful when removing the auxiliary charging base cover.
  4. Bem Wireless HL2739B Charging Base Battery Replacement: step 4, image 1 of 2 Bem Wireless HL2739B Charging Base Battery Replacement: step 4, image 2 of 2
    • Using the tweezers, pull the wires from the auxiliary charging base's internal chip.
    • Be careful not to damage the chip when you remove the wires
    • It will likely require soldering to reassemble the auxiliary charging base after this step.
Ryan McQueeney
446 Reputation
4 Guides authored
USF Tampa, Team S2-G4, Nance Spring 2017 Member of USF Tampa, Team S2-G4, Nance Spring 2017
USFT-NANCE-S17S2G4
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,928
