Bem Wireless HL2739B Speaker Motherboard Replacement
  1. Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Battery: step 1, image 1 of 1
    • Peel the rubber cover back from the corner of the speaker to reveal the screw.
    • Repeat for the three remaining corners.
  2. Bem Wireless HL2739B  Speaker Motherboard Replacement: step 2, image 1 of 3 Bem Wireless HL2739B  Speaker Motherboard Replacement: step 2, image 2 of 3 Bem Wireless HL2739B  Speaker Motherboard Replacement: step 2, image 3 of 3
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
  3. Bem Wireless HL2739B  Speaker Motherboard Replacement: step 3, image 1 of 1
    • Lift the bottom cover away from the rest of the speaker.
    • There are wires connecting the battery and cover to the rest of the speaker. Be careful when removing the base cover.
    • Using the tweezers, pull the wires from the speaker's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the speaker after this step.
  4. Bem Wireless HL2739B  Speaker Motherboard Replacement: step 4, image 1 of 1
    • Using a plastic opening tool, gently pry the battery from the metal base.
  5. Bem Wireless HL2739B  Speaker Motherboard Replacement: step 5, image 1 of 1
    • Using tweezers, pull the wires from the metal base connection.
  6. Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Motherboard: step 6, image 1 of 2 Bem Wireless HL2739B  Speaker Motherboard Replacement, Speaker Motherboard: step 6, image 2 of 2
    • Unscrew the four 10mm screws from the motherboard.
  7. Bem Wireless HL2739B  Speaker Motherboard Replacement: step 7, image 1 of 2 Bem Wireless HL2739B  Speaker Motherboard Replacement: step 7, image 2 of 2
    • Using tweezers, remove the blue/white and red/black wires from motherboard.
  8. Bem Wireless HL2739B  Speaker Motherboard Replacement: step 8, image 1 of 2 Bem Wireless HL2739B  Speaker Motherboard Replacement: step 8, image 2 of 2
    • Gently re-position the motherboard so you can access the bus wire connected to the speaker.
    • Remove bus wire from the speaker and lift out the motherboard.
Ryan McQueeney
446 Reputation
4 Guides authored
USF Tampa, Team S2-G4, Nance Spring 2017 Member of USF Tampa, Team S2-G4, Nance Spring 2017
USFT-NANCE-S17S2G4
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 916
