Bella TXG-FS075A Touchscreen Replacement
    1. Bella TXG-FS075A Touchscreen Replacement, Touchscreen: step 1, image 1 of 3 Bella TXG-FS075A Touchscreen Replacement, Touchscreen: step 1, image 2 of 3 Bella TXG-FS075A Touchscreen Replacement, Touchscreen: step 1, image 3 of 3
      • Use a spudger to pry off the metal top of the air fryer.
      Ask FixBot
    2. Bella TXG-FS075A Touchscreen Replacement: step 2, image 1 of 2 Bella TXG-FS075A Touchscreen Replacement: step 2, image 2 of 2
      • Use an iFixit opening tool to pry off the plastic frame.
      Ask FixBot
    3. Bella TXG-FS075A Touchscreen Replacement: step 3, image 1 of 3 Bella TXG-FS075A Touchscreen Replacement: step 3, image 2 of 3 Bella TXG-FS075A Touchscreen Replacement: step 3, image 3 of 3
      • Remove the four 13 mm screws from the second plastic frame using a Phillips #2 screwdriver.
      • Pry off the black plastic frame.
      Ask FixBot
    4. Bella TXG-FS075A Touchscreen Replacement: step 4, image 1 of 3 Bella TXG-FS075A Touchscreen Replacement: step 4, image 2 of 3 Bella TXG-FS075A Touchscreen Replacement: step 4, image 3 of 3
      • Remove the singular 13 mm screw using a Phillips #2 screwdriver.
      • Slowly lift the sides of the screen from the body of the air fryer until all corners are loose.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 61
All Time: 712
