Shop the Holiday Gift Guide
Beboncool Wireless Switch Pro Controller Buttons Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
77
All Time:
578
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide describes how to remove broken or damaged buttons for the BEBONCOOL Wireless Switch Pro Controller.
The Beboncool Gamepad has many buttons that all operate in the same manner. A broken or malfunctioning button is rather easy to identify when not getting the correct response or no response at all when pressing the button in a game. Replacing the button will likely fix the issue.
Tools
    1. Beboncool Wireless Switch Pro Controller Buttons Replacement, Motherboard: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the seven 5 mm screws from the back of the controller.
      Ask FixBot
    2. Beboncool Wireless Switch Pro Controller Buttons Replacement: step 2, image 1 of 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: step 2, image 2 of 2
      • Gently separate the top and bottom halves of the controller.
      Ask FixBot
    3. Beboncool Wireless Switch Pro Controller Buttons Replacement: step 3, image 1 of 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the two 5 mm screws holding the joystick motherboard in place.
      Ask FixBot
    4. Beboncool Wireless Switch Pro Controller Buttons Replacement: step 4, image 1 of 1
      • Carefully move the bumper buttons out of the way.
      Ask FixBot
    5. Beboncool Wireless Switch Pro Controller Buttons Replacement: step 5, image 1 of 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: step 5, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 5 mm screw holding the motherboard in place.
      • Remove the motherboard.
      Ask FixBot
    1. Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: step 6, image 1 of 2 Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • To remove the alphabetic buttons, remove the translucent silicone cover.
      • Use tweezers or your fingers to remove the buttons.
      • Pushing a button from below will elevate them enough to easily grab them.
      Ask FixBot
    2. Beboncool Wireless Switch Pro Controller Buttons Replacement: step 7, image 1 of 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: step 7, image 2 of 2
      • To remove the directional buttons, first remove the translucent silicone cover. Then, use tweezers or your fingers to remove the button pad.
      • As with the alphabetic buttons, push on the buttons from below, then grab them.
      Ask FixBot
Author
with
Tayah Appel
529 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 77
All Time: 578
